Oil tank vent
Oil tank vent
I inherited this bike and I am going to finish.
I built an oil tank with no filler (thinking I could top off through the return line.)
This engine is new factory engine built 10 years ago
bike has always been inside heated garage
UNFIRED
something tells me I need to vent the tank to atmosphere even though I have been told otherwise
The top two lines are vent and return from oil pump, the bottom line is for feed
VENT OR NO VENT?????
UNFIRED
Oil tank must be vented. It connects to the engine case fitting above the oil pump in the last photo. With the wide spread top entry fittings in the tank, I'd recommend you use the the left side for oil return and right side (carb side of engine) as the vent connection. I'd work either way but all things considered, that'd be the safest routing. You don't ever want the vent below the oil line.
I can't make out what carb that is and cannot tell if the engine breathers on the heads are plumbed to vent correctly. May be fine, just can't tell from the jiggled photo # 1.
Received 5,424 Likes
