Oil tank vent
No vent needed, the engine breathing arrangement will take care of that regardless whether it's a top or bottom breather.
You WILL need to solder a standpipe in each of oil return and crank case/tank vent fittings. Feed comes of the bottom of course but the other 2 must be above the oil line in the tank at all times. Preferably, you'd make a short "L" on each pipe and index each so they do not point at each other. Better yet, so the return points toward the fill and the case/.tank vent is pointing away from fill.
Omaha Derby Covers (01-16-2023)
98hotrodfatboy (01-19-2023)
