FXD dreams
#61
Turned out they are/were custom chrome. Swapped earlier this year. I found and polished up a set of HD boxes. Turned out to be a very good thing I did. Once disassembled found they were cracked, and the towers were whored as well as most of the rocker arm bushings.
So HD boxes, and s&s rocker arms and shafts....solved a problem I would have been unaware of except for puckered chrome and a small oil seep.
#62
Buy and wrench on enough used bikes you'll see a lot, but there's always something new under the sun, for sure.
#63
Man, I can't stress enough how important it is to thoroughly go thru a 'new' used bike. After even one owner, you never know what you'll find. My uneasiness with the forks was justified, the preload was barely set and the front trees literally fell off once things were loosened. GO THRU YOUR BIKE. Riding is dangerous enough without have your bike being a time bomb..... /rant
Glad I took this on. Glad i can afford decent tools for specific jobs. The Fast Eddy driver I picked up made quick work of removing the races, The George's installer made quick work of installing them. The old races were a bit notchy, lube was good though.
A few pics;
bottom race
top race
removed race
installed races
Race-less
prep
greased bearings in a zip lock, where the magic happens. Less Mess
A few pics;
bottom race
top race
removed race
installed races
Race-less
prep
Tommy C (08-08-2024)
#64
98hotrodfatboy (08-08-2024)
#65
Gots some two step in the middle and the paving company finally showed up. I'm getting gassed in the gay-rage, **** stinks.
Lots of little steps. Happy with the outcome, even though the front fender doesn't quite line up. No biggie as I'm putting a 16 on once the parts come back from strip and powder coat. The '05 brake line up perfect as well, no shims needed.
a little soldering
16 i'd like to run
a little soldering
16 i'd like to run
#66
#67
98hotrodfatboy (08-09-2024)
#68
Got out for a hour shakedown. Bike much nicer riding now. More planted and the vague wandering is gone, should have done this before I put her on the road. Future miles will be much more comfortable.
Got a 'new' 16 off fb marketplace, it'll polish up nice, and more importantly its not whored out; threads and bearing seats are rock solid. The 16 for the front would look awesome, but the cost for a strip and powder coat is a bit much. I'm still shopping it around, but probably going to get a spoked 16 for the front.
Totally roached chrome
Tires shot...big deal
#69
#70
@98hotrodfatboy yeah, had a Tiwian 'lifetime' 41mm set of legs and knockoff accutronix wide glide trees. Unknown chrome caliper as well. So back to HD parts, bit mix and match. Much, much better handling and all the weird up front noises are gone. Added bonus the turn signal cancel works again after cleaning up the wiring.
I've got some rust removal and painting to do. Otherwise guess I'll build the motor this winter...just because.
