Wheel bearing installation tool
Hi guys I’m planning on replacing the wheel bearings in my 94 fxdwg, I found this tool on Amazon: MOSTPLUS Wheel Bearing Removal and Installation Tool Compatible with VT102 Harley Davidson | Pullers and Installers with 3/4 inch I.D. 1 inch I.D. and 25mm 94134-09 https://a.co/d/6WQMrQ9
does anyone know if it has the right size bushings? I’ve been searching for the id and od aspects for the bearings and google wants to keep that s**t a secret. Is it 3/4” id on this era of bikes?
Thanks in advance
Thanks in advance
Scottyxbones (02-09-2023)
Thanks in advance
Thanks in advance
I have spent nearly half a day, ruined numerous high quality punches and almost destroyed my wheel trying to get those races out. Do not try to "make do" with anything except the correct tools... and even then, they can be a pain to remove and replace.
https://www.georges-garage.com/produ...ver-installer/
https://www.georges-garage.com/product/driver-handle/
https://www.georges-garage.com/produ...driver-handle/ (you can get by without this piece, but works a lot easier if you have it)
The following 2 users liked this post by t150vej:
LowriderHarold (06-08-2022),
Yankee Dog (06-07-2022)
The tool you mentioned will NOT work. They are for Twin Cam sealed bearings
Respectfully Disagree.. If a Blind Race Puller, won't get it.. I treat em like a Steering neck Bearing.
Worth searching the procedure, but basically I weld a bead around the inside of the race, and it literally "pops" out.
TwiZted Biker (06-09-2022)
The following 3 users liked this post by t150vej:
OP, why are you replacing the bearings?
As has been mentioned already, these are serviceable tapered roller bearings. A clean and re-grease with each tire change, and they will last the life of the bike. These aren't like later model ball bearings where regular replacement is required.
If you've inspected yours and they are indeed bad (indicated by any pitting or spalling on either the rollers or the races), then by all means, replace.
But if you're thinking of replacing just because, my $0.02 is you don't need to.
Yankee Dog (06-09-2022)
The following 2 users liked this post by 98hotrodfatboy:
86glider (06-08-2022),
The following 2 users liked this post by Racepres:
98hotrodfatboy (06-07-2022)
To this day I replace the wheel bearings anytime I get a used used bike regardless of what they look like. I don't even inspect them, as soon as I get a bike home I order front and rear sets. Am I crazy? Maybe. The irony is I don't even know if I would immediately recognize the symptom of a bad wheel bearing and don't think I know anyone who has ever had one go. Funny how some things stick with us even if they may not be logical.
