I rejetted my carb - a couple of ?'s
RE: I rejetted my carb - a couple of ?'s
ORIGINAL: SLC Rider
Lbussy, I actually live in Murray.
I have ordered a new needle, and a 40 and 44 slow jet, I have main jets 160-180 already. I will have to look into a dyno tuner here in town. I don't trust our Harley shop and others in the area have said the same thing. I have a mechanic who has been recommended by a couple of riders but he doesn't have a dyno. If you get that info from Denver that would be great, they are about 1000 feet above us in level.
I forgot the link in my last post for the instructions. Here they are. It's written for a Sportster but the instructions for setting the IMS are the same.
I decided to dive into this again yesterday, spent a good 6 hours "tuning" the carb and here are my conclusions thus far. The 42 slow jet with a 170 main seems to be the combination I am looking for. Bike runs good with 3 1/4 turns out on the air mixture screw. It is slightly on the lean side (VERY light tan on the plugs). I kept going back and forth between the 42 and 45 and the 45 slow jet runs too rich. I have ordered a sporster needle which I am thinking will put me where I want to be jet wise. I have also ordered a 44 slow jet so I may tinker with that a bit. The other issue is the gas mileage. I have ordered a rebuild kit as well, I am going to pull the carb apart when I get the needle and replace all the gaskets and adjust the float. If the gas mileage is still bad I may end up replacing the carb.
ORIGINAL: bullelkklr
Sorry to interject your post - but I am in Denver and my '86 evo is running rich - and I would like to put her on a dyno....how much are they and who should I go to? It is stroked 96CI s&s build.
If you call, tell Dan (he answers the phone) that Lee Bussy sent you. It won't save you any money but he'll know all the excellent service they've given me in the past has some benefit besides my thanks. :-)
ORIGINAL: SLC Rider
It's not way off what I would expect, but enough that if you spend 6 hours to get it right it should be better.
http://faq.f650.com/FAQs/SparkPlugFAQ.htm#Plug%20Chop
Update, I received my new gasket kit and jets for the carb and decided to dive into it tonight. I pulled the carb off and disassembled it and cleaned everything. I think I found the cause for my bad gas mileage. Someone has put a dynojet kit in this one which I have read can cause a loss of 10-12 mpg. It has a dynojet needle in it and looks as if there has been some drilling done on the slide.
For the time being I stuck a 44 slow jet in and 180 main for now. The needle is set 3 notches down. I tried 4 notches down but the bike ran real bad so I put it back to 3.
I am not going to mess with this any longer and am going after a new carb. I am most concerned with reliability and gas mileage at this point. Am I better off going with another CV or should I go S&S or Mikuni?
[IMG]local://upfiles/36715/3523B3EA187F4DF49BF990B3A957E0A3.jpg[/IMG]
ORIGINAL: SLC Rider
My S&S Super E works good, came on my bike, and I like the fact that I can adjust the accelerator pump shot with an externalscrewand enjoy zero lean surge without having to take the carb apart to achieve it. But I would never have spent the $350 or more to get an S&Sif I already had anOEMCV.A better running bikealmost always means burning more fuel over stockno matter what carbyou use because the factory sent them leaned out. We've all heard the miracle stories but, bigger jets andthinner or raised needles (at cruise, you're primarily running on the needle) all cause reduced gas mileage. At the Harley dealership where I worked, the techs were awesome at tuning CV's, and their advice was always the same: keep theCV on standard displacement bikes (or up to 85-90 HP) and go with a Mikuni foreverything else. That dealership depends on repeat business and gets it, so they don't treat customers as one-timers. If it were me, I'd try another used CV (probably not necessary) before I'd spend the bucks for a new carb. Like LBussy said, I would go back to standard parts and then start over.
I bought a minty CV througheBay for $50+ shipping. I'm going to throw it on this winter when I change out my cam and see how it goes compared to my present set up. At my elevation, I'll start with a #47 pilot, #185 main,shim the needle .05", and leave slide undrilled. I'll go up or down on the pilot jet until the idle air mixture screw is, hopefully, 1.25 to 1.75 turns out (I like the low speed a little rich if anything)from lightly seated at best running. This combination, or something very close to it,has worked well for me on several bikes (EVO's) in the past. At your elevation you may end up with smaller jets, but I'll refrain from making a WAG.
The dyno "expert" that "tuned" my S&S carb adjusted the idle air too rich, and it ran poorly until I changed it back to where it was. He also left my low speed (S&S calls it an intermediate jet)as-is, which at a .75 of a turn out on the idle air mixture screw,indicates that the intermediate jet was at least one size too rich. He changed the main jet, which is very easy to do , from a #72 to a #68, and said that he had saved me some gas. Wrong! I don't cruise at WFO so it made no difference at all, except it was crisper running hard up through the gears. In other words, unless a dyno guy is willing to really do something for his $100+ an hour fee, you're left with learning how to tune for yourself, and it'll take hours of reading and fiddling. Once you've been through it a few times, you'll get very close on your own. I thought I'd get some magic for my money, and hadn't worked on an S&S before, but in the end, I just needed to pay my dues and learn the carb. In other words, keep at it, you can do it, especially with your previous experience.Tells us how it runs in detail, symptoms and at what RPM's, and it will be easier to zero in on what to do next. Good Luck!
