Rear brake rotor help please
1999 softail. I felt the rear end dragiing when I went to move the bike. Jacked up the bike and rear wheel is locked up. Looked at the rotor and it’s bent all the way around. Any ideas? All I can think of is the last time I rode it my rear brake pedal got caught on the exhaust and made the rear brake stick. Did it overheat and warp that fast? Everything lines up as far as belt and pulleys n stuff. Before I took it off of the lift after powdercoating the swing arm it all spun freely.
The following 2 users liked this post by im:
98hotrodfatboy (07-18-2021),
blumi (07-24-2021)
Received 4,361 Likes
All you have to do is replace the rotor.
I had the same thing happen to me a few years ago and I replace the rotor and then went through the rest of the system looking for the cause and found nothing.
I have no idea why it happened but I haven't had any problems in the 6 or 7 years since I had to replace my rotor.
Just for fun when you replace your rotor I'd suggest flushing your brake fluid.
