LED dash lights
You don't say exactly what bike you're dealing with, but, going by your user name and signature photo, I'm assuming you have a 1995 FLSTN. That was the last year of the "old style" dash with individual indicator lamps and mechanical speedometer.
That being the case, I did that modification to my FLSTN some years back. I used these for the indicator lamps:
BA9s LED Bulb - 1 LED - BA9s Bulb | Super Bright LEDs
I used these for the speedometer lamps:
BA9s LED Bulb - 4 LED - BA9s Bulb | Super Bright LEDs
As you can see, they come in your choice of color, so you can customize your instrument lighting.
You will likely find that the high beam indicator is way too bright at night. I ended up putting a few layers of neutral density filter under the lens in the dashboard until I knocked the brightness back to a suitable level.
Hope this helps.
Hope this helps.
Blk/Wht/andChrome (07-23-2021)
oh yeah sorry, you're correct. i have a 1995 flstn. nice touch on the speedo light uncle g! how many bulbs were inside and was it easy to get to? (haven't taken the speedo off yet) i just placed my order for the other lights. going with the color coded ones too as you have shown. any chance you have pics of everything all buttoned up?
Sorry, no pics of the finished installation, but they're very BRIGHT. That bike was destroyed by a careless driver in 2019.
The stock speedo has two lamps, one at six o'clock and one at 12 o'clock. To get at the speedometer lamps, you will need to remove the dash cover and remove the two e-rings that hold the speedometer to the dash panel. Then the sockets can be accessed from underneath. The sockets are just snapped in place and can be removed by rocking them back and forth until they come loose. The aftermarket speedometer I show has only a single bulb.
slight exaggeration only, folks!
Originally Posted by Tee⋁20049773
jeez, I forgot about that. I'm guessing you never made it to sixteen million miles on the rebuilt motor?!
I've done this a few times and I'd recommend you choose your bulbs carefully. Some illuminate to the only the sides and not the end, others do on the side and end. You can also get them with different levels of lumens (brightness) I found the end lit to be too bright for the dash lamps indicators and too dim for back lighting the speedo\tach. I was able to paint over the end to dim the output to a level I didn't need shades at night.
They are inexpensive, I'd suggest you but a couple different styles\lumen levels in the colors you need and try them in the dark. Choose the one that works best for you before you have to assemble\disassemble if you decide to change from the first choice.
The following 2 users liked this post by EFELESTEEN:
Blk/Wht/andChrome (07-23-2021),
Uncle G. (07-14-2021)
Goose_NC (08-02-2024)
