Metal Shavings in Oil Filter (after collapsed lifter)
Old 05-15-2021 | 10:59 PM
Ghostultramarine's Avatar
Ghostultramarine
6th Gear
Default Metal Shavings in Oil Filter (after collapsed lifter)
I had a lifter "collapse". (I will add a picture from my 'phone but I hate trying to type on the tiny screen...)
I went to change the oil filter (no, I have not started the bike since replacing the lifters) and there are metal flakes (magnetic, bright shiny steel colour) in the filter - lots of it.
Please advise what I should do next.
Thank you, in advance.
Old 05-16-2021 | 08:11 AM
Dr.Hess's Avatar
Dr.Hess
Ride the bike. That's what I would do. The filter did it's job. Any damage is already done, so it's either all going to be OK or it's not. You might consider changing the filter at a shorter interval for a time or two.
The following 3 users liked this post by Dr.Hess:
eighteight (05-17-2021), evotrike (05-16-2021), sicky (05-16-2021)
Old 05-16-2021 | 09:05 AM
daven9113's Avatar
daven9113
It really depend on how badly worn the lifter was, and how long. What does the cam lobes look like? Since you pulled the lifters out, I would open up the cam chest to inspect, then you will know if you can clean it out and do what Dr. Hess suggested. This is a tough call. Some guys will tear the motor apart and clean, and others will try to clean out as much as possible and hope that nothing got into the crank. I gambled and lost on this one. I might be bias on the pulling everything down and do a thorough cleaning, and if there are a few miles on the bike, it would be a cheaper refresh then new engine.
Old 05-16-2021 | 09:20 AM
IBDAGRIZ's Avatar
IBDAGRIZ
What exactly is a "collapsed lifter" that produces that much metal and not take out something else?
I'm a fan of pulling the oil pump and cleaning out all the passages, asI have seen it get built up in the corners of the galleys.
Additional inspection depends on what you find.
Griz
Old 05-16-2021 | 09:32 AM
0maha's Avatar
0maha
I'd want to know if the lifter was a cause or a symptom.
Old 05-16-2021 | 09:50 AM
t150vej's Avatar
t150vej
Hate to be the bearer of bad news, but I suspect the lifter is a symptom and you've got more problems. Take the oil screen out and check is easy. I bet if you remove the cam cover, the cam chest will be full of metal...
Old 05-16-2021 | 10:58 AM
Ghostultramarine
6th Gear
Just to be safe I am going to pull open the “nose cone” and take off the oil pump.
The oil pump is an S and S and I want to clean it out and check it to be safe.
I ran a magnet on a flexible extender around the oil tank and no metal filings.
The filter did not have a lot a lot of miles on it.
I was just not expecting to see the metal.
The lifter had had been ticking for a while, then it got louder and louder (trying to ride home on the highway) then very loud and then the engine stopped. I trailered it home.
The tappet screen was perfectly clean.
Old 05-16-2021 | 11:19 AM
EVOrider's Avatar
EVOrider
Hopefully the oil filter captured everything…..but, inspecting the cam chest would be a good idea.
I’m assuming everything is stock since the rivets are still there. If that is the case, at least change out the cam bearing to the Torrington. Also a good time to change the cam if you’re interested, but maybe required if damage occurred.
But, if you’re on a budget…..stick to what Dr. Hess said.
Old 05-16-2021 | 01:43 PM
Ghostultramarine
6th Gear
I am always on a budget (young children).
It looks stock, but isn’t. There’s a cam with Torrington.
I use Twin Cam oil filters for the extra filtering.
Old 05-16-2021 | 05:45 PM
BB.No8's Avatar
BB.No8
The EVO oiling system is not designed to run Twin Cam oil filters. I would not run them on my bike.
