Dyna S Ignition
Dyna S Ignition
Ok guys I am getting closer to firing this ole girl up, however in need of some help! Bought a Dyna S ignition and am unable to figure out how to attach the advance thingy to the cam shaft??? The original screw is to short for the thing and instructions say to slide it over a shaft some where??? I have once again been stumped so came here for some answers. I have attached a few pictures as well.
Thanks again,
Original advance thingy...
This is what is supposed to be in there now
Thanks again,
Uhhhh.... Looks like you still have the timing cup installed on the cam shaft. ?
The Dyna S unit requires a mechanical flyweight advance identical to a breaker points system. https://www.denniskirk.com/american-...rd/2012534.sku
Some makes of units have needle bearings, this one doesn't but whatever you do, stay away from cheap ones. Some of the other guys may have better recommendations for the best brand/type.
The following 3 users liked this post by t150vej:
The following 2 users liked this post by TwiZted Biker:
sparky0496 (03-17-2021),
t150vej (03-16-2021)
Yes. The flyweight unit is about the same thickness as the rotor cup. It will have an index notch for the cam, like the cup. Your S rotor will hook onto a flyweight ear, long bolt goes in last....
Received 4,361 Likes
Yankee Dog (03-18-2021)
Adam76
07-13-2020 06:00 AM
