Evo oil filter question.
Old 03-15-2021, 01:34 PM
TedMan's Avatar
TedMan
TedMan is offline
Originally Posted by t150vej
Stick with the 51215 or 51214 and you'll be fine.
Thanks, only reason I asked is on Wix Cross reference they list 57348 and 57148.
Old 03-15-2021, 01:48 PM
TedMan's Avatar
TedMan
TedMan is offline
What's weird is that Wix's site lists the 57348 for 1996 Heritage Classic, but the 51215 for the Fat Boy?
Old 03-15-2021, 01:58 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,917 Likes on 1,430 Posts
I use OEM Toyota filters.
Old 03-15-2021, 02:38 PM
t150vej's Avatar
t150vej
t150vej is offline
Received 1,828 Likes on 1,187 Posts
According to MoCo, they redesigned the drain back and bypass on the TC filter 10-12 years back so it can be used on Evos also.
Obviously HD doesn't make their own filters so I reckon if you run aftermarket, go with manufactures specs or use the 63798-99A if you wanna use HD brand.
TedMan (03-15-2021)
Old 03-15-2021, 03:20 PM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is offline
Received 2,096 Likes on 1,047 Posts
I use the wix 51348 which I believe crosses for the toyota filter. The 51348 has the larger micron rating (compared to the twinkie filter but the correct micron rating for the evo). Used it for years. Easy to get at auto chain stores. It is a little smaller in size than the stock filter for the dyna, but I am good with that. YD
https://www.oilfilter-crossreference...vert/Wix/51348
Old 03-15-2021, 06:22 PM
TedMan's Avatar
TedMan
TedMan is offline
Good historical info. Thanks all.
Old 03-15-2021, 08:38 PM
EVOrider's Avatar
EVOrider
EVOrider is offline
I’ve been using a motorcraft 910s oil filter and sometimes the Toyota oil filter.....no ill effects with either.
Old 03-16-2021, 01:16 AM
fireman64's Avatar
fireman64
fireman64 is offline
Received 1,583 Likes on 329 Posts
Thanks guys I appreciate all the feedback.
Old 03-16-2021, 10:27 AM
Lil'Mugsy's Avatar
Lil'Mugsy
Lil'Mugsy is offline
1 is chrome and 1 is black.
Old 03-16-2021, 11:39 AM
daven9113's Avatar
daven9113
daven9113 is offline
Run the best, forget the rest, and it matches all shades of blue.
Quick Reply: Evo oil filter question.
