Turn signal wires front and rear.
Thanks
The signal lamps will not blink unless there are two bulbs drawing current.
The flasher gets power from the accessory circuit (Orange wire).
A Green/Black wire runs from the flasher to the connector for the right turn signal switch, where it branches over to the connector for the left switch. The wires between the connectors and the turn signal switches are solid Green.
bulbs.
I'm back to work today through Monday so I won't be able to look at it anymore until late Monday at least. I can wire up 2 1156 bulbs just to test it though.
Perfect, thanks.
If this works and I still want to go with led lights, does this system work with resistors? One for each side wired to the brown and purple wires?
Everything I see for the resistors says to stop the hyper flash. I'm guessing that's with the electronic modules.
Thanks
Almost seems too easy lol.
And I'm only seeing one flasher so I'm guessing no hazard function. At least in old cars it was 2 separate flashers.
I plugged the new flasher in to test.
Are they supposed to continue to blink or is it set up that way so I don't forget to turn them off?
Thanks so much everyone for your time so far walking me through this.
