Top-End Rebuild
Top-End Rebuild
Base gaskets leaking with 65K mile, so I disassembled my 98 FLHTCI and took heads and juggs to shop today. Shop telling me to replace the cam, lifters and cyclinder studs also. Looking for inputson the extra parts. Already over budget on the new pistons, bore and head rebuild parts and labor.
Should I replace the studs?
Should I replaces the cam and lifters?
Thanks
Thanks
RE: Top-End Rebuild
While I was working at a Harley dealership in the service department I saw many base gasket replacement/top end rebuilds. The newer style gasketshave a much lower failure rate than theoriginal EVO parts. At our shop, replacing the cam bearings with Torrington was a no-brainer, defintely do it. This is a perfect time to improve power with a better cam, and we installed a lot of SE-3 HD cams (identical to the EV-27) at this time, although many cams with 65K are stillserviceable, often depending on how well the bike was serviced. If you've been contentwith the stock cam you'll probably flip out when you ride your bike with an SE-3 or EV-27. They are, in my experience and opinion,the best compromise for the average EVO rider, especially for those who weren't complaining about not having enough power with the stock cam. I remember a lot of happy campers who upgraded the cam, it seemed to take a lot of the bite out of the money they just spent. Replacing the lifterswas nearly always done as well, even with less mileage than you have, and like the base gaskets, the newest OEMlifters have a lower failure rate. I've seen bikes with over 100K that were still running original lifters but have also seen them fail with much less mileage than you have. It's a piece of mind thing as far as I'm concerned. I don't recall the studs being replaced all that often, but when my bike is ready for a top end rebuild I'll replace mine, again, for piece of mind. I think the advice with you got was good, if you go by it you really can't go wrong.
RE: Top-End Rebuild
Agree. That Andrews EV27 spec gives you gobs of useful power where most people use it, (rpms) and you get a nice little bark from the lope. You'll notice an increase in power.
You'll get a real kick out of it, enough to take some sting out of the money you need to spend.
If you have to replace the cam, why go with stock?
RE: Top-End Rebuild
If you replace the cam with an EV27 (or similar to stock lift height) you can save some money and use the stock pushrods since you have the top end taken apart anyway. Even if you don't replace the cam (which you will be sorry for later), at least replace the cam bearing with a Torrington and replace the lifters.
