S&S 107 to 113 question
Gentleman, I bought a S&S Evo Super Sidewinder bottom end with the 4.25 flywheel assembly, it was paired with 4 inch bore jugs for a 107CID engine.
My question is I know the S&S built 113 engines were a 4 inch bore with a 4.5-inch stroke, but can I run 4.125 jugs on my 4.25 stroke to get to the same 113cid?
The cases are S&S 31-0024 the same cases that S&S used with 4.125 bore and a 4.625 stroke for their evo super sidewinder 124 engines, so I am thinking jugs and pistons should be available?
Any thoughts?
Thank you in advance for your time and consideration.
Any thoughts?
That's a huge amount of money spent for virtually no real increase in anything but 6 cubic inches of displacement.
A 4.25 stroke has less piston speed, so will last longer than a longer stroked engine. I say this owning a 4,5" stroke 113" engine and a 4.625 stroke 96" engine, both of which run just fine.
Griz
Griz
