CV carb identification.
G'day Fellas.
Matt, yes sorry typo it is 42.
Mike. yes that's how I checked the fuel height.
T150vej, thanks, that's what I thought. I'll aim for level with the joint (carb horizontal).
Just puzzled as I took the time to set up a jig at 15 degrees and set the float height to 11mm (half way in the specs) but got a fuel height of 3mm above the joint. I'll try 20 degrees and see where it ends up.
I'm no stranger to setting carbs up if I have the std specs and go from there. Been fiddling with'em for 50 years but no-one knows everything! That's where Forums like this (and great members) are a godsend.
Cheers
Cheers
Hard to describe how to hold it, but the goal is to have the float needle seated, and the tab on the float just touching the tiny spring loaded shock absorber "tit" WITHOUT compressing it.
As mentioned, usually having the float "parallel" with the float bowl body and no compression, is a good guide if no means of measuring. I agree, the fluid level tube is a great way to confirm, but bike needs to be sitting up in the riding position. YD
G'day Fellas.
Thank you all for your input.
Yesterday I pulled the 99C apart. This is the one I'll use. I set the float height (as per instructions) and ended up with 13.5mm height to bring the fuel height to level with the joint surface (carb sitting horizontal). It now has a 45 slow jet but still a 190 main, the next size down I have is a 175 so will order 180 & 185. Everything looks good, all passages are spotless.
Now for the bummer. Both carbs are missing the starter (enricher) valve so it's all come to a screeching halt till I find one and make a cable to go to the choke **** in the dash panel. I'd also like to utilize the "cruise control" if anyone can point me in the right direction. Last question. On the 99 there's two tapped holes at the butterfly shaft below the starter valve. Is this for a throttle position sensor? Not that I'd need one,flat out or stopped are my two preferred positions LOL.
Cheers
Cheers
I don't remember you mentioning your cam but may have overlooked it. If it's stock or very mild, a 175 will work but having the 2 extras you mentioned is a good idea.
You can buy the entire (aftermarket) cable/enricher assembly, though I don't know about shipping or availability down there. Even the HD cables seem cheap but they work. I never used the others and hear they work OK but the cables portion is really junk.
Otherwise you need:
27583-88 Starter Valve
27315-88 Spring
27581-88 Starter Cap
27580-88 Cable Guide
27582-88 Cable Sealing Cap
29236-90 Cable, enrichment
The actual cable part will only be long enough to reach the left side under the tank, so making the choke work with your dash mount may take some creativity.
There's been a few on here over the years who have re-installed the cruise on their newer models but I don't recall anyone retro fitting. There's a lot of electrical and special parts that will be near impossible to find and suspect it would be a "bridge too far" trying to make it work like it should.
Otherwise you need:
27315-88 Spring
mike131 (01-08-2021)
Otherwise you need:
27315-88 Spring
Otherwise you need:
27315-88 Spring
Thanks Fellas.
so making the choke work with your dash mount may take some creativity. That's my middle name LOL.
The "cruise control" is just a cable so may use one of those old choke/advance levers off the Pommie bikes. Just finding one to fit 1" bars.
Found a cable local, asking for the other bits. Will know Monday.
Cheers
Cheers
Thanks Fellas.
Cheers
Cheers
To simply fashion a throttle lock other than the handlebar drag control is easily doable but dangerous. They make thumb extensions for the star wheel on the grip, they work pretty good and are inexpensive.
Here's mine. This style hard to find lately, less than $10. just push on. But they break if you try to take them off. There are others for sale these days though I've not looked lately.
If you're inventive or know how we used to repair and modify cables back in the old days, by putting a ball end on you long style choke cable, I can see how you can make the dash mount choke cable work. Actually, that would be really cool and hope you'll post back with photos.
One last thing, replacing the butterfly Keihin with the CV, I recommend you replace your throttle cables with post '89 cables. Otherwise you'll have to cut approximately 3/4" off the housing of one of your cables. Easy to do but I always replaced cables on every one I did since. Been 20 years since I switched one using old cables and cannot remember whether it was the idle or pull cable that required housing modification.
mike131 (01-09-2021)
G'day YD.
Yes that thumb wheel is there but doesn't seem to work and would be a pita to use.
G'day t150.
Yes I've seen those extensions for the thumb lock. Will be second choice if I can't make the cable system to work. I'm not shy to making cables.
Bugga, just put new cables on. Thanks for the tip, will do.
May be a while before I get back to this project. The 1951 BSA needs a full motor rebuild. Been 30 years since I did the bottom end.
Thanks for the help Fellas.
Cheers
G'day t150.
Cheers
You can rebuild the workings under the thumb wheel - parts still avaliable thru HD. In fact I highly recommend doing that if even considering a gadget like I posted. They do work well but ONLY if the drag shoe and spring are in decent shape.
Since you just replaced your cables, just go ahead and "trim" the housings they'll be fine. The one I trimmed had 15 year old cables - it was a rush job. Again, cant remember which one need the housing shortened, may have been both. Either way, it was very straight forward, just spread the housing coil and cut.
Have fun
Have fun
Muskrat21 (01-09-2021)
