“Click Click” Noise when engine/oil is hot
Hello everyone! I ride a ‘97 FatBoy (evolution engine/80ci) and it is making a clicking noice (as if two spoons were banging against each other) seems like it’s coming from the rocker boxes (top of the engine). The noice begins only once the oil/engine temperature goes over 200 degrees F and the bike has been running for at least an hour. Cold start or just regular cool/warm start is just fine, no noise at all.
Bike only has 20k miles. Just had it serviced: new lifters/tappets, new adjustable push rods, All fluids changed (running 20w/50 oil). Also found out that previous owner had put a cam inside the engine.
I thought changing out the lifters and push rods would resolve the clicking issue, however, the noice is still there and it only begins when bike is idling or in Neutral (engine is hot at this point already). The clicking noise gets higher when I easy of the clutch but goes away right away once the gear is fully engaged.
I tried to bring it to several mechanics around me and everybody seems to thinks it’s lifters and push rods. Once I tell them all of those parts were changed their answer is then we don’t know what could be causing the noice :/ If someone has an idea or suggestions of what to do next I would really appreciate the advices.
Thanks a lot for all the suggestions!
*video link is attached to hear the noise (on the bottom of this text) In the video I’m riding on highway and the clutch is pushed in and I’m just rolling. the clicking noise is so loud and clear that it’s even heard when just rolling in Neutral.
https://drive.google.com/file/d/16wI...w?usp=drivesdk
The following 3 users liked this post by daven9113:
Racepres (09-26-2020)
It's extremely difficult to diagnose a noise thru a video but I can hear it very well, just not able to pinpoint like in person.
The push rods could be hitting the covers. Need to know what brand/model push rods before we can give you much more info. And it'd be good to know what brand of lifters were used. Some of the cheaper ones have too large of an oil feed hole in the plunger and can cause it to starve the rockers as well as not have enough to keep the lifter bodies filled. If you can, post a photo of one of the push rods with the cover slide all the way up.
Hot engine, the oil pressure drops substantially at idle and it may not be keeping the lifters pumped up all the way. Since it only makes noise when up to temp, I'd first go with proper adjustment of the push rods as Daven and YD mentioned.
Also a slight possibility (but rare) that the "new" cam gear is totally mismatched (too small) to the pinion gear. That will cause a lifter-like noise too. Can't honestly say I ever had hands on with that problem, but it's noted in the manuals.
danielbardz (09-26-2020)
Edit: just watched the video, sure sounds like a loose lifter to me.
⚠️serious problem⚠️
Thank you all for trying to help! you guys Rock! ✌️
all the reasons you names are new to hear to my ear. New information definitely. But sounds like reasonable issues that you named. And I’m very thankful for that. Will definitely notify my mechanic about these reason and start investigating. BUT LOOK WHAT HAPPENED JUST NOW ON MY NIGHT RIDE BACK HOME FROM Long Island to Brooklyn. The bike just stopped idling properly (shuts down if choke is not up) and had to raise up the idle screw on the carb to feed more fuel to keep it running. Got to the garage and what I see is the entire engine soaked in oil. Flashed some light around the engine and found oil coming out from the spark plug. Took it off cleaned it, put it back on ran the bike and oil still seems to be coming out of the plug hole. The engine also started making a new sound as if it is a steam train 🚂. Video link: https://drive.google.com/file/d/1vhF...w?usp=drivesdk
I have no clue what’s up with my bike ... 😔
The following 2 users liked this post by K. Lindberg:
danielbardz (09-28-2020),
Felipe Xavier - Xavi (05-13-2021)
The following 2 users liked this post by Yankee Dog:
