Pin Removal Tool
Received 4,361 Likes
Received 8,422 Likes
At about the 45 second mark you see how the tube style works on our evo's. Slip the hollow tube over the pin connector so it compresses the locking tab. Then the pin will pull out of the plastic connector housing.
The only difference with the one in the video is it has a button on the end to push the terminal out of the housing.
The one in the pic above still compresses the locking tab, but does not push it out of the housing. The wire just needs to be gently pulled out of plastic connector housing after pin locking tab is compressed by the tool. You need to find the correct size "hollow tube" so it will compress the locking tab, then pull on wire while tool is still in place.
If the tube is to large it won't compress the tab.
Some guys can locate and compress the locking tab with a pin, a paperclip, etc. I have never been that lucky. YD
fireman64 (12-14-2019)
Uncle G. (12-18-2019)
I had pretty good luck using the tool that the OP is asking about, takes a little fiddling (they all do), but I have also had luck using a straightened out paper clip, just get inside and push the tab against the terminal and pull the wire out.
My `89 Softail has the connectors that were used through `95 (AMP Mate-n-Loc).
If you see one of these online, don`t waste your money :
You just have to remember it's plastic and not overstress it.
That said I found in my manual a phone number and a part number for a metal one that I haven't broken yet.
These things are on the Namz website for 59 dollars......maybe they are not the same, but I`m not going to find out.
