Why, Hoping there's a good reason
Putting the bike back together and it looks like the PO did some changes.
The VOES has a piece of rubber zip tied at the top. My first Why
The violet/w wire that the VOES plugs into leads to the ignition control module plug in
And the other why, is there is no ignition control module. I'm assuming due to the bike having a Dyno s going directly to the coil, bypassing the module, but any thoughts on the VOES.
What role does the Violet/white wire running from the VOES to the removed ignition control module play. I've studied up on this till my eyes bled but i'm not connecting the dots. The bike ran and idled fine pre tear down.
If I read this correctly... The Ignition has been replaced with a Dyna-S???
The Dyna -S has No Provision for VOES... it is Basically Electronic points... Including the mechanical advance mechanism... which Must be kept in Operable, and Within "tolerance" condition!!!!
The VOES is Not in play and is just along for the ride....
Note that in general...the wire is useless from the VOES, and the Vacuume line attachment at the manifold Must be Plugged...
If I am Mistaken...and this is Not a Dyna-S ignition..... well all this is BS
and the VOES should be utilized as outlined previous...
Durham man (10-20-2019)
It is also possible the P.O. adjusted the VOES for a different vacuum setting.
That adjustment screw has a seal over it and must be removed to make the adjustment.
After the setting is established, that adjustment screw must be sealed off again (silicone sealer works just fine) to prevent a vacuum leak which would very probably affect the VOES operation.
And like Racepres said, if the ignition doesn't use the VOES, then ya might as well remove it and seal the vacuum supply to it.
98hotrodfatboy (10-19-2019)
[QUOTE=Racepres;18619632]If I read this correctly... The Ignition has been replaced with a Dyna-S???
makes sense.
When I pulled the wire Harness a few weeks back and noticed the sealed off valve with a zip tie across it, I made a note in my rebuild journal to research what the hell this was. Going to be close to 90 Sunday, we riding ?
