1986 Heritage front brake light actuator problem
Old 07-30-2019 | 12:05 AM
Punisher2000's Avatar
Punisher2000
Default 1986 Heritage front brake light actuator problem
Hi, My 1986 Heritage (Bought it new in 86) is constantly giving me the same problem. The front brake light switch actuator keeps slipping out of place and the brake light stays on. I have tried everything, had it apart hundreds of times, just rebuilt the master cylinder, align the actuator over and over and it slips off the brake light switch. Is there any modification or change I can do. driving me nuts.Help!!! Thanks
Old 07-30-2019 | 12:23 AM
JustDave13's Avatar
JustDave13
Veteran: Marine Corp
Take it off (remove it from the equation) and just rely on your rear brake switch to do the job.
IronAss (07-30-2019)
Old 07-30-2019 | 06:30 AM
grbrown's Avatar
grbrown
Red face
In some places, certainly here in the UK, that isn't an option - two brake light stitches good - two working switches compulsory! There has to be a solution for P2000, so let's keep our thinking caps on.
Old 07-30-2019 | 06:52 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I would start with a new PIN and switch. 45031-82a and 45051-82.... They might be hard to find but Google might help and always check the dealer maybe they can find one some where in the system.
Old 07-30-2019 | 07:19 AM
Dan89FLSTC's Avatar
Dan89FLSTC
The updated P/N is 71590-92A
Make sure the brass wedge or something similar is in there to hold the switch in place.
EDIT: I was thinking of the wedge on the `96 and later, the switch on your control setup should be held in place by a screw.
Old 07-30-2019 | 07:28 AM
JustDave13's Avatar
JustDave13
Thanks, I didn't consider that
Old 07-30-2019 | 07:51 AM
Tom84FXST's Avatar
Tom84FXST
If you are tired of fooling with it...a banjo bolt switch will solve the problem....
https://www.google.com/search?q=banj...l6jBgCM:&vet=1
The following 2 users liked this post by Tom84FXST:
Dan89FLSTC (07-30-2019), IronAss (07-30-2019)
Old 07-30-2019 | 09:16 AM
ChopperBill's Avatar
ChopperBill
Had the same problem. Found that the lever that pushes the button on the “normally on” switch was slightly bent and sliding off the button. Loosened the throttle and took a pair of needle nose pliers and bent the end of the lever so it could only slip to the down and not up where it can slide off the switch. I know this sounds complicated but once you study the dumb idea the Harley had you will figure it out. I’ve put up with this problem for years off trying too fix it permanently. Now the brake light works better than it ever has.
