Advice on removing an exhaust stud.
Old 07-18-2019 | 09:15 AM
grbrown's Avatar
grbrown
Talking
Originally Posted by jcsurf
Thanks Guys for your replies going to work on it after work, I'll post the results.
We'll be lookin' over ya shoulder!
Old 07-20-2019 | 03:01 PM
jcsurf's Avatar
jcsurf
Well I finally did. Had to buy the JIMS tool to do it, but it cam out great. I'm kind of a tool nut and I always say buy it once and do it right many times. Thanks again guys.
Old 07-20-2019 | 06:51 PM
Mattbastard's Avatar
Mattbastard
So was the stud broken all along? I got the impression you just wanted to remove them, unless I missed something.
Old 07-20-2019 | 09:49 PM
QdawG's Avatar
QdawG
Stage I
Default Heat!
I had to remove exhaust studs on a couple of car engines bcuz they snapped off. I used a torch and heated the block (right around the stud). As the block expanded the stud was able to turn. If the stud breaks then hopefully you have enough meat to weld on something that you can turn it with! Good luck!
Old 07-21-2019 | 02:16 AM
john lee's Avatar
john lee
i thought all shovels had 1 bolt each pipe not 4 studs
TF3N
04-26-2024 01:37 PM
Jwideman6207FXD
06-18-2019 01:27 AM
elecwiz1
Exhaust System Topics
03-14-2014 02:30 PM
jnorbros1
01-24-2012 08:35 AM
Lil Truckr
03-20-2007 10:41 PM
Quick Reply: Advice on removing an exhaust stud.
