Bike cut out lost power
Old 07-09-2019, 05:57 PM
edjhover1's Avatar
edjhover1
edjhover1 is offline
Default Bike cut out lost power
1990 fxrs Bike died no power , ticking noise coming from main breaker. disconnected battery negative cable sparking. ?
Had the same problem last week and tore all apart looking for a short. put it back together and it fired up . can anyone suggest the problem
Old 07-09-2019, 07:23 PM
bagga's Avatar
bagga
bagga is offline
replace the main breaker.
edjhover1 (07-14-2019)
Old 07-09-2019, 07:40 PM
edjhover1's Avatar
edjhover1
Smile
Thank you I will get one , I'll repost if it works
I apprieaciate the help
Old 07-10-2019, 11:12 AM
edjhover1's Avatar
edjhover1
Default replaced main breaker
attempted to connect negative battery cable it sparked bad....any suggestions?
Old 07-10-2019, 12:40 PM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is online now
Received 2,043 Likes on 1,031 Posts
As Bagga mentioned, did you replace the main breaker? If you did, then it is time to start looking for a dead short. D
Old 07-10-2019, 01:35 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 20,117 Likes on 5,824 Posts
Even if the breaker was bad it would not cause the sparking...you should have some other breakers...disconnect them one at a time, and see which one eliminates the sparking...
This will give you a clue which circuit has the short...
The following 2 users liked this post by Tom84FXST:
edjhover1 (07-14-2019), WesternNSW (07-14-2019)
Old 07-10-2019, 01:56 PM
edjhover1's Avatar
edjhover1
Thanks, i’ll follow your advice, I will post results. Thanks again!!
Old 07-13-2019, 09:44 PM
edjhover1's Avatar
edjhover1
Thumbs up
followed advice found that the ignition wire(red) at switch was worn through. repaired wire and bike fired up as normal. Thank you so much for the advice,
Dan89FLSTC (07-14-2019)
Old 07-14-2019, 09:21 AM
Beemervet's Avatar
Beemervet
Beemervet is offline
Congrats
Now you owe us a bike pic.
Old 07-14-2019, 03:47 PM
edjhover1's Avatar
edjhover1
Default 1990 fxrs
Quick Reply: Bike cut out lost power
