The tale of new Front Bearings
Old 07-03-2019, 09:21 AM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
Originally Posted by evotrike
Was getting loose handling on my '98 Ultra trike. Was going on 2 hr. road trip with the wife up to Paris, Tx....70-75 mph.
25 miles from destination a low growl eminated from the front end. I knew that sound...wheel bearing. Turned around , did 50mph back home.
And get a pint of rusty water out of the hub. And that ain't all..
An absolutely destroyed bearing.
This my friends is why you don't run a pressure washer over your wheel seals.
WesternNSW (07-08-2019)
Old 07-03-2019, 09:24 AM
evotrike's Avatar
evotrike
evotrike is offline
Never have, THC, but someone sure did.
Old 07-03-2019, 09:31 AM
texashillcountry
Dirt don't hurt
Didn't think you did as you've only got about 1k on the bike but it was a great pictorial on why not to do it!!!!
Old 07-03-2019, 09:34 AM
evotrike's Avatar
evotrike
evotrike is offline
Yep, don't know how it was still turning. As I have NO luck, I put it to divine intervention.
Old 07-03-2019, 09:36 AM
texashillcountry
Dirt don't hurt
I'd say you're lucky as hell not to destroy the wheel by riding it as far as you did on a bad bearing.
Old 07-03-2019, 09:38 AM
evotrike's Avatar
evotrike
evotrike is offline
The interior of the hub was still perfect....crazy.
Old 07-03-2019, 09:44 AM
texashillcountry
Dirt don't hurt
The interior of the hub was still perfect....lucky.
Not crazy.
Old 07-03-2019, 09:57 AM
LQQK_OUT's Avatar
LQQK_OUT
LQQK_OUT is online now
Received 1,658 Likes on 1,130 Posts
Old 07-03-2019, 10:06 AM
evotrike's Avatar
evotrike
evotrike is offline
Good links for the folks, Lookout.
Thanks.
Old 07-03-2019, 03:19 PM
Bumpandrun's Avatar
Bumpandrun
Bumpandrun is offline
Next time no need to make parts for bearing races...i even own the puller to do them and weld flat washers in races as the heat lets them slid out 1 little tap....Flat washer and 2 mins later driving new bearing races in after in the freezer..... Done them at a gas station one time. Lol. Also bearing are only 18 bucks for both at tractor supply. Just trailer axle bearings...even number is the same. Same with neck bearings. The added bonus of using a flat washer? Weld and ild car headbolt in to center...go over to grinder.......grind 3-5 thou off of bearing race and bingo nice race driver. They go in about 2 hits when u freeze them for a short time.. Lol
Quick Reply: The tale of new Front Bearings
