Why does my idle speed keep jumping around?
Received 5,259 Likes
I'm loving the performance of my 1994 Fatboy after the re-jetting the other night, but now I'm having a problem that I hope is something simple.
I can set the idle to what feels about right after warming the bike up, but then if I goose the throttle, it comes back to an idle that's WAY too high. Conversely, sometimes when sitting still and idling, the idle speed will drop to a point that the engine threatens to die and has a couple of times.
Have any of you experienced this? Could it be the mixture screw setting? The throttle cable(s)?
Any help is appreciated.
For 1994 bikes, the vacuum line from the carb goes to the VOES. The voes can develop a leak from just the age of the part. Or it could be the vacuum hose to the voes, also as mentioned the intake manifold to head or carb to manifold seal. I would replace the hose first and see if that fixes your problem. I think you recently replaced the manifold O-rings?
If the hose is good, and the voes is original, might be worthwhile to test the voes with a meter and a vacuum gauge (like mighty-vac or similar) . Even if they don't leak, the switch inside the voes has contact points that get oxidized over the years and the resistance increases. The meter will tell you what the resistance is. Not saying that is the cause of your problem, but I am saying that it may be worthwhile to test the voes for a leak. You don't have to remove the voes to testm but you do need to get at the wire connections and the vacuum line at the carb, so maybe fuel tank removal. You can also hear the voes click when the vacuum is applied triggering the switch inside.
If you don't have a mighty vac, you can at least check for a leak by applying suction. If it holds it good, if it don't then it leaks. The meter is optional but those are just a few bucks at harbor freight if your on a budget...
It's just another suggestion in what to check, good luck. YD
Slight variation in idle speed from a cold bike to a warm bike is normal, mine idles higher when it is warmed up, so I adjusted my idle to 1000 rpms when at normal operating temp nut it should not rise and fall like your experiencing. YD
Windseeker (06-30-2019)
So I'll try the vacuum line first. Mine was a bit of a pain to get on. Maybe I should also look at the seating of the carb, because maybe I didn't get it quite right? I'll have a look tomorrow.
And, I assume that year has a vacuum operated petcock so there will probably be a "T" in the vacuum lines. Eliminate all those possible leak areas before you go any further.
Received 4,361 Likes
Windseeker (07-02-2019)
