LED Bulbs?
Old 06-06-2019, 04:49 PM
0maha's Avatar
0maha
0maha is offline
Received 4,679 Likes on 1,665 Posts
More like #2.
Old 06-06-2019, 05:28 PM
bentparts's Avatar
bentparts
bentparts is offline
Default Brake/ tail lamp
My battery supplier for work turned me on to a Halogen tail light bulb that's at least twice as bright as the 1157. Don't have a part number but it's available at Batteries Plus Bulbs.
Old 06-07-2019, 08:53 AM
splattttttt's Avatar
splattttttt
splattttttt is offline
Twice as bright? On my way there!
Old 06-07-2019, 09:42 AM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,917 Likes on 1,430 Posts
Careful on the halogen replacements. Check the current draw. Our electrical systems are not exactly designed for heavy over use.
I put some 1157 LED replacements from amazon:
https://www.hdforums.com/forum/evo-c...ight-bulb.html
Took a bit of modding to get them to work in the tail light.
Old 06-07-2019, 10:26 AM
t150vej's Avatar
t150vej
t150vej is offline
Received 1,825 Likes on 1,184 Posts
Hey DrHess,
Glad you chimed in and thanks for the link. I was on my way out the door to go shopping. I'll be sure to take my calipers with me
Old 06-07-2019, 10:49 AM
RhynoRocK's Avatar
RhynoRocK
RhynoRocK is offline
I use Sylvania LED bulbs from autozone or walmart in my rear lights. My front turn signals are actually a bulb that's also used for household accent lighting, which walmart sells in an LED.
But you can get a stock replacement LED bulb that won't require you to gut your headlight assembly to install, just replace the bulb with one of these. There is a catch though, your headlight has to have either the cone shaped reflector inside, behind the outer glass, or the glass on your headlight needs to be diffuser type (you can't see thru it clearly) for these to work well. Also they are bulky, they have a cooling fan housing on the back side, so room may be an issue.
Amazon Amazon
My 96 Road King uses a 9003 headlight bulb, but they have em in other types as well.
Old 06-07-2019, 04:42 PM
t150vej's Avatar
t150vej
t150vej is offline
Thanks for all the advice/info guys.
My headlights are 5 3/4 sealed beam and there's NO room in my Tour Glide fairing for alternations depth-wise so I knew from the get-go that was out of the question.
Today I tried each style of LED 1157 and 1156 they have in town which are basically what I posted in photos earlier, in the turn, tail/brake lights. The original incandescent bulbs (made in USA) were 30-40% brighter. I guess it's just the way the reflectors and/or lens are focused. Yes, every bulb on my '87 is original except the headlights which I've replaced twice. Good news is, I won't go spending 120.00 bucks to replace turn, brake and running light bulbs. That'll buy me about 1800 miles worth of fuel
Old 06-07-2019, 09:12 PM
bentparts's Avatar
bentparts
Default electrical system power
Been using the same bulb for 2 years now, two cross country rides and plenty of weekend travel. No issues so far, but I do have an upgraded alternator. Come to think of it I'm also running a 100/80 halogen headlight bulb and that's been in there for many years without issue. got it from a Jap bike dealer.
Old 06-09-2019, 10:44 AM
sB43's Avatar
sB43
sB43 is offline
I put LED's in my brake /tail lights and they worked. Tried them in my turn signals and no go. (2000 Ultra)
hoakken
EVO
01-30-2018 01:38 PM
WOLFE1584
09-17-2013 07:20 PM
Radalack17
03-27-2010 08:57 PM
CANTDR55
10-27-2008 01:36 PM
CREEPSHOW
01-13-2008 10:03 AM
Quick Reply: LED Bulbs?
