1985 Electra glide won't turnover
05-24-2019, 07:37 PM
Bikes got a hot battery. Turn switch on, kill switch on, and it does absolutely nothing when I hit the starter. I've cleaned all the connections to the starter, solenoid, relay, and breaker. Still does nothing. I'm also noticing that the instrument lights dim in and out when I turn the switch on. I'm confused as where to start my search,lol. Thanks
05-24-2019, 07:47 PM
Check the circuit breakers those do go bad, will show voltage but won't take a load.
05-24-2019, 11:10 PM
05-25-2019, 12:52 AM
Try turning the bars side to side while holding start, move wires around. Had this happen on a '96 once & turned out to be a bad wire.
05-25-2019, 06:30 AM
Many times I have found a bad ground to be the culprit with this same scenario, but don't rule the starter out either.
"Still here"
twistedironshop
Electrical/Lighting/Alarm
42
06-24-2017 10:18 AM
Jeff Vorhies
03-22-2015 01:09 PM
guitarman023
08-12-2013 07:09 AM
Panboy4999
02-21-2012 07:27 PM
BlackDenim&Chrome
05-23-2011 06:14 PM
