Can the rear brake pedal travel be adjusted?
Except for pipes and air cleaner, I have a stock '98 Dyna Convertible with mid-mount pegs. Shortly after buying the bike, I had to rebuild the rear master cylinder because the rear brakes just didn't work right. Because of that, I never got a feel for how far the rear brake pedal should travel before the pads actually do their job and start squeezing the rotor. After the M/C rebuild, the brakes work okay but, the brake pedal travels probably 3/4" before I can feel the pads engage the rotor. There is an adjustment on the brake rod that runs from the pedal to the M/C but, that only affects the resting height of the pedal. Is there a way to adjust anything that will reduce the travel of the pedal before the pads actually do their thing? I have a '94 FXR and '05 Dyna with mids and none of those pedals are like this one. Anyone have any ideas? Maybe I screwed something up when I rebuilt the cylinder? Try bleeding them again? I dunno so, here I am.
When I did mine, I noticed there as a large and constant stream of air coming out of my drain line from the rear caliper. Given the fresh fluid and flush and constant stream of air - the only conclusion I could arrive at given the lack of leak of anywhere was that air was coming in from the rear master cylinder. I haven't rebuilt it yet but the problem hasn't ever gone away and that is the only place it could be coming from.
I think my next step will be to see how far the pedal travels before the stop light switch is activated since it's activated by pressure and not by position. I might have a better idea of where to start looking. My guess would be that if it takes only a short distance then I have a problem somewhere between the master cylinder and the pads. If it still seems like it goes too far before the switch turns on the lamp, I have a problem between the pedal and the end of the push rod that goes into the cylnder.
That's certainly a possibility although the feel of the brakes seem to be fine. Not spongy or weak when they actually start working. Gonna give that a shot (bleeding) and see what happens.
rchinjohnson
04-17-2013 03:38 PM
