berring/wurring noise ?
ok guys!!! im new to this sight and harleys!!! i posted a question on the soft tail forum,and didnt really get too much info. ive also done a search and found nothing. this noise is starting toget worse and its bugging me!!! ive got a 99 nightrain and im hearing a wirring noise comming from the cam area,it sounds like a berring is going bad kindof. now... im a mechanic and am not affraid to to tare this babby apart,i just dont wanna tare it apart and have a lot of down time.like i said im new to harleys,only had her for a year or so,so thats why im askin this here. please help this is my babby and i dont want her to get anny worse!!! thsnks!!!
RE: berring/wurring noise ?
ORIGINAL: lowglide88
I dont own a TC88.. but if I'm not mistaken I thought that there was a problem with eitherthe cam bearings or the rod bearingson the early TC's... I'm not 100% which ones..I would contact the HD dealer and ask...sorry I couldn't be more infromative
Yeah, I think I would open it up! about the only thing that would make that kind of noise on that side of the engine would be the cam drive gears, if the cam bearing is going south you need to take care of it NOW!!! If it is ok you will have the peace of mind that it's not the bearing, and you could go ahead and change it before it does become an issue. It's better to inspect it and have a few days down time. or I guess you could just keep on listening to the noise and have a month or two down.
OK now we will need some more info. is the noise always there? or 1; when transmission is nut. w/the clutch out, or in? 2; in gear with the clutch out. or in? 3; when moving? 4; in any certain gear? 5; does it change with engine speed? 6; does it change with road speed? is the noise worse or less at any time? and last, is there oil in the primary and transmission? I could prob. tell you what it is just by listening to it, but thats really hard over the internet, so any info you can give will help bunches.
ok !! its aloways there,sounds faster when you rev it ,and i here it most when i down shift to 1st. i just serviced the primary drive and adjusted the chain,thinking that was it! wile i was in there i didnt see annything out of the ordinary! the drain screw/magnet? had a littlebit of mettle flakes on it but nothing too bad. i only got 1 notch out of the chain tensioner adjustment,dont think i gotthe chainto tight. dont think its ever been serviced! itsgot 24000 mi on it! and i dont know about the oil in the trans, where do i check it? thanks crampfan !!!
If you have'nt tried it yet.....get either a auto stethoscope or a cutoff piece of broom handle or thick dowel rod.....and give a good listen all around the area....This usually helps ALOT in narrowing down the exact area the noise is comming from...[ not always of course ] Also might try and checking your fluids for METAL shavings or chips?....good luck
