Medium well done primary
So I I had some funny noises and maybe some chain slapping in my primary. Noticed it a few days ago and took a look through the inspection hole today and it's not looking too good. The chain was loose as hell and there wasn't much oil in it. I've got everything off except the inner cover. As best as I can tell it must have been leaking from behind the inner primary at the bottom of the motor. I never saw one drop of oil under it either. The adjuster shoe had shallow grooves in it but not too bad.
I'll finish pulling off the inner primary in the morning then go to cleaning everything. I"m planning on replacing the chain and all of the seals/gaskets in the inner and outer. I'll have to take a look at the clutch plates too. They were new from Barnett and had less than 2,000 miles on them. I'm hoping I don't have to replace them but not sure. Is there anything else I need to look at/replace while I've got it apart?
carl
carl
Received 4,361 Likes
carl
carl
About the only thing that kills them is incorrect adjustment.
Will be following this thread, going to be tearing into mine soon. I plan on using the Baker IPB.
Getting all the parts and tools together. My problem is I have a 1994. Don't know if it uses the early 1994 (and earlier parts) or the late 1994 on parts. I suppose I will find out when I take things down.
I agree with THC, your clutch should be good. Good luck with the project. YD
How much is "not much oil in it" As long as you had a few ounces in it I doubt the chain is no good. They are much heartier than you think... Just fix the leaks and through it back in and get it adjusted properly... I set mine to 1/2".. Never an issue, not even with 110 hp.... By the way I'm still running my original chain with over 70K on it...
Oh that chain is shot. When I adjusted it prior I had about 7/8" in it. When I checked it the other day I could touch the top of the chain case with it easy.
I might have had about 1-2 oz of oil that drained out of the primary. The chain was original and had roughly 90k on it so I'm not sweating the money.
The bike is a 98 RKC. Parts are on order. I should have this buttoned up in a good week.
Carl
Carl
