2 evos in one week
How much do you want to spend? The sky (and your pocket book) s the limit.
The 98 will need an inner cam bearing. For more power, put a cam in it while you are doing that. The CV carb on it can be tuned to improve it with the new cam.
The 84 will need a carb. S&S or a CV. A cam will help that bike a lot. It will also need new lifters, so that's a good time to put the cam in also.
The simple things, in addition to the good Drs suggestions, are replace the airbox, if stock, also the mufflers, plus the ignition module. The stock airbox is actually a muffler and along with the exhaust mufflers, cam and ignition system are all designed to comply with emissions regulations, which restricts noise output as well as performance.
My first thoughts as well.
Not likely that either bike is stock. Figure out what you have before guessing what you need.
Wouldn't a 84 FXR be a shovelhead?
