Kuryakyn Forward controls 97 DL
The worst problem I had with Kuryakyn was with a module that made the rear turn signals work like brake lights.
It worked for a little while but then it started causing all kinds of issues with the turn signals.
I've bought 4 of their products and had 5 (one came on a bike I bought) and every one failed in a really annoying way.
I had a set of their highway pegs that even lock-tight couldn't keep from coming loose but then again I didn't try red maybe that would have worked...
Spend the scratch and get something good. Buying a Krackalackin part is dumb. I've personally found that more often than not, the H-D stuff works better than the aftermarket stuff, not always but mostly. It's more expensive, but I won't worry about it not fitting or not working or falling apart soon.
