85 evo compensator stuck
Old 03-16-2019 | 07:46 PM
Decilmoto92's Avatar
Decilmoto92
Stage I
Default 85 evo compensator stuck
I'm currently pulling apart, upgrading, and just flat out restoring my 85 FXRS. It has 56k on the clock and before tearing into it was starting having some electrical and engine gremlins. So I decided to restore it but have ran into a roadblock. My compensator assembly refuses to budge and I just want to double check I'm not missing anything. My current assembly is not how my Harley manufacturers manual shows it. In the manual it shows a compensator assembly as having a single nut that is to be turned counter clockwise to remove. My assembly does not look like that and looks like the compensator below. Idk if this changes anything in the procedure to remove (From what I've searched and found/didn't find) it doesn't. Now I've searched suggestions are to heat it with heat as its probably got a whole bottle of red loctite on it and has probably been on there for some miles but between a torch sitting in the groves on the shafts for a good 5-10 mins (behind the cover) a 24 inch breaker bar, with a cheater extension, strapped to a stable platform, a primary locking tool, and a 220 lbs of weight pressing down on the bar. It still won't free itself. I also don't have an impact anymore (Not that youre suppose to use one on these as it could mess up the shaft or stator) so that not an option.
Am I missing a step? I've followed my manual up to this point 100% on my tear down, but this has got me stuck. Any advice or suggestions are appreciated!
Old 03-16-2019 | 08:21 PM
hdvespa's Avatar
hdvespa
My compensator looks just like yours on my 85 Flhtc. I be used a 1/2 air impact to take mine off in the past. Otherwise you need a jam bar and a bigger breaker bar
Old 03-16-2019 | 09:06 PM
bagga's Avatar
bagga
my 85 has the same thing. heat it good, i just heat the hex head. red loctite is used to keep it tight. i use a 1/2' impact air gun to get mine off after it's hot.
Old 03-17-2019 | 05:54 AM
sB43's Avatar
sB43
I made these myself out of 1 1/2" PVC , but here's a definite helper. I can pull the compensator no problem.
https://www.jpcycles.com/product/930...ary-drive-lock
https://www.jpcycles.com/product/911...rive-lock-tool
Old 03-17-2019 | 07:34 AM
LQQK_OUT's Avatar
LQQK_OUT
A number of people suggest that one does NOT use the wedge type or stepped primary locking tool and instead use a primary locking bar or block of wood. They say the wedge type tool places excess stress on both the transmission and the primary chain.
Shoveldan78 (07-16-2022)
Old 03-17-2019 | 07:48 AM
TwiZted Biker's Avatar
TwiZted Biker
I've seen guys crack the primary using those incorrectly.
OP , heat and an impact, bet your *** that's the way those have been getting pulled at dealers forever. The don't use an impact mantra didn't start till the twin cams and their cheap easy to tweak flywheels.
Old 03-17-2019 | 08:31 AM
sB43's Avatar
sB43
The PVC is semi soft. The sprockets bite into it pretty well, as well as the chain. So no real stress on the chain or metal. And it's good for maybe 2 uses. It's the same PVC that we carpenters use for exterior cornice work. I just had a big chunk left over from a job, and said ,"Hey, I know what I can use this for!"
tar_snake (03-18-2019)
Old 03-17-2019 | 10:03 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
The first time I took mine off I didn't have an impact so I used a cheater bar.
The cheater bar that ended up long enough was 5' long.
Now I use an impact!!!!!!!!!!
I use a cut to length piece of bar stock I got a home depo to lock the sprockets.
Old 03-17-2019 | 10:05 AM
texashillcountry
Dirt don't hurt
I don't know your experience with HD's but the compensator nut is right hand thread and the clutch hub nut is left hand thread.
Just thought I'd throw that into the mix.
Old 03-17-2019 | 10:22 AM
megawatt's Avatar
megawatt
I use the polyurethane stepped blocks but I use two of them, one on each sprocket.
After heating the hex head of the nut, you should be able to remove it.
Quick Reply: 85 evo compensator stuck
