Starter change
Starter change
I wasn't sure whether to put this in the Evo section or the electrical section. I had the bike torn down for a bunch of wiring repairs this winter. After reassembly last weekend I put gas in the tank and went to start it. After a few revolutions the starter began smoking. Now I've had the bike for almost a year and it was always a little sluggish so I had a feeling a new starter was going to have to be put in eventually. Even after a new battery and start solenoid it changed nothing. OK so I ordered a new starter which showed up yesterday so I did a little research and found that the primary cover has to be taken off to remove a bolt at the end of the shaft in order to pull the starter out. Did that today and looked at the way it all hangs together. I'm reasonably mechanically inclined with cars and trucks but not bikes just to be clear. What I'm having trouble wrapping my head around is that if I take the nut off the end of the shaft and the 2 bolts which hold the housing to the inner primary it's all going to come off in one piece? If so it's going to be a really tight squeeze
Received 4,361 Likes
Pulling the clutch hub makes this job much easier.
I needed to take out the 2 through bolts and the starter came right out. I've never had to do this with any of my other bikes so I'm going in blind with this one. Because of my inexperience with bike mechanics I took out the 2 bolts that held the starter drive on where one of them snapped off inside. Drilling and tapping this hole with the space I have is going to seriously suck! A lot of times I learn by phucking **** up.
I didn't want to get that deep into it but I have no choice, I opened up a can of worms on a simple starter change. Like I said earlier I'm somewhat mechanically inclined but not on bikes so I guess this would be a good way to get more familiar with it. I'll know more once I get it apart but I wonder if there's enough material around the hole to put in a thread insert? Just a thought
98 Heritage N.Indiana
EVO
02-21-2011 10:54 PM
