Those 4-pot brake caliper adapters
03-06-2019, 07:49 PM
These things:
Are they symmetrical? I've got a couple calipers from newer models that are supposed to fit with these adapters, but I'm not seeing one for Left and one for Right.
03-06-2019, 08:36 PM
03-07-2019, 07:16 AM
I have a set of those I will give you if you want them...
03-07-2019, 07:42 AM
Quote:
Originally Posted by
flhchaz
Oh hell yea! Thanks man, PM sent.
03-07-2019, 08:12 AM
Mattbastard
pm received and replied
03-07-2019, 08:18 AM
Be aware sometimes you need to shim things a bit with those adapters to get everything to sit square & true otherwise they work well enough.
03-07-2019, 08:04 PM
TwiZted Biker
Thanks man, that's the easy part. Washers/shims and bolts I got, cutting and chroming metal is a lot more of a chore.
03-07-2019, 10:49 PM
I have a set of 4 piston calipers from a fat Bob if you need 80$$
03-08-2019, 06:16 AM
brad75raiders
Thanks but I already got the calipers. Just need the adapters (and maybe bolts and shims and whatnot).
Coupla months ago I would have taken them tho.
03-08-2019, 06:25 AM
I'll send the hardware I got with them. I think there are bolts, but no shims. I'll get into the shop and see what all is there and will post a pic before I ship them
