True duel exhaust
True duel exhaust
I have 1995 Electra Glide Ultra classic with EFI that I'm in the process of switching to a carb. My question is I've found a set of true duels online that where on a 1984 Electra Glide FLHT and would they bolt on my bike. I have a Fullsak conversion kit on it now but want to eliminate the clamps and joints. Thanks in advance Steve
Received 4,361 Likes
Maybe because if you have a carb problem it takes a few minutes and a screwdriver to fix it and if you have an FI problem you're gonna sit there until a tow truck or a trailer shows up to pick you up and take you home...
MM EFI systems aren't the best that Harley has ever used but if you keep up with it and if you can find the parts for it then it will work just fine.
