What do you guys do for oil lines? 1990 flhtcu
I'm at the point where I need to plumb my engine oil lines. My original oil lines were brittle, and had multiple thin spots from rubbing against other hoses etc.
I'm having trouble with 3/8" hose wanting to kink where they go to the oil pump. Any one have any options there? Don't really want to use braided lines, not my style. Nos lines are hard to track down...so, I'm sorta stuck at this point. I was thinking if I could make a 90deg hardline off the pump, then go to rubber, anyone done that? 5/16" hose doesn't kink, but i don't think that would work
The following 2 users liked this post by 98hotrodfatboy:
fernominal2011 (07-02-2022),
Hey Man (02-15-2019)
Try King's idea, but also go to the parts store and ask to go where ever the hose is, fuel injector hose will take a bend without kinking better than regular fuel line, but my point is to go and try bending different hose they have to test which works better.
Also, napa usually has all their molded hose hanging up, when I need to rig something like that, I go and see what they have to work with, maybe use parts of molded hose and hard (brake) line to get what you need to work.
The following 3 users liked this post by Schex:
