Tach finally coming
Old 02-10-2019, 08:02 AM
glidein wide's Avatar
glidein wide
glidein wide is offline
Default Tach finally coming
Just purchased a tach finally ,ideas limited but I do have a plan that hopefully works out. I will post pics as I go, tips ideas are welcome of course. Tach came with a handlebar clamp but ain't doing that. Gonna make a bracket of sorts to go center of bars right above the speedo.
I need to mill some of the clamp flat, my so called print should give you the idea.
Old 02-10-2019, 08:14 AM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,423 Likes on 1,733 Posts
Only H-D that needs a Tach... is a RaceBike...
We Racing?? Get an Autometer tach...
Old 02-10-2019, 08:39 AM
glidein wide
no racing, except for when my friends get excited, tach is not my need, I want, it's a four banger so I'm curious about highway revs and maybe the idle, my car and truck have oem and not racers. Plus I don't have a limiter.
Old 02-10-2019, 11:16 AM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
When I made a mount like that I put some spacers in the holes you are using and got some longer bolts so that the bolts cam all the way to the bottom of the riser using all the threads.
If you need some I can send you the spacers I used as I've since gone to a different tach.
Old 02-10-2019, 01:02 PM
glidein wide
Thanks Tex, we'll see how it goes, this one is extra so I don't mind milling it flat just where the holes are, and will get longer bolts for those two.
Old 02-10-2019, 03:01 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 5,476 Likes on 3,650 Posts
Hey Kevin, Whats the outside diameter of that tach. I have an extra mount that bolts to the 2 top bolts of the bar clamp... It's your's if the diameters are the same.. Just gotta find it..
glidein wide (02-15-2019)
Old 02-13-2019, 05:48 AM
pjb's Avatar
pjb
pjb is offline
Not sure I see the value of adding the tach, or the look of it hanging up there, but why not just get a speedo with the tach built in?
Old 02-15-2019, 11:25 AM
glidein wide
I didn't even consider that, I recently purchased a new OEM speedometer from the dealer.
Old 02-15-2019, 11:32 AM
98hotrodfatboy
Neither do I... I don't even see why some one would even make a statement like that when it's not their bike or tach...???
I wish my OEM tachs were working... Right now it's just mounted and looking good.....
Old 02-15-2019, 11:55 AM
pjb's Avatar
pjb
pjb is offline
I know the aftermarket has a direct fit speedo with a tach in it, and I seem to remember HD offered one also. But maybe that was only for late models.
Quick Reply: Tach finally coming
