Went For Compression Releases And...
I had a ground up motor rebuild done 13,000 miles ago. The shop that did it did not install compression releases and it would kick back when hot. Thread on the build is here:
https://www.hdforums.com/forum/evo-c...o-rebuild.html
I've had issues with the shop that did the build and won't be going back.
Southern Cycle and Head Hoggers are doing this work. When they pulled the heads, the valves looked terrible. Definitely didn't look like they had just 13k on them. They also pulled the jugs to look at the bores and the pistons. Rings had flat spots and the bores were scored.
They are going to clean up the head porting that should have been done originally, clean up the valves and re-grind the seats, viton valve seals, install compression releases, boring the cyclinders, Wiseco 10:1 pistons, Woods W6H.
Bob...98hotrodfatboy thanks for the advice!
98hotrodfatboy (02-01-2019)
When you own an HD that says you should own a set of wrenches and know how to use them.
That was always the case until the tail end of the baby boomers decided to fill their bucket list.
Now some mistakenly think they can own a trouble-free HD
When you rely on someone else, you better look at their resume and references.
Looking at your seats there -too dam wide! HS!
They must have forgotten stem seals or sized the guides about .003 over?
Do I see wear marks on the stems?
Never heard of flat spots on rings
With a proper cam I doubt you need CR releases...but that is for another argument
Good luck!
Good luck!
I've run that setup for quite sometime. Lots of usable power with reliability, providing the shop doing the work is reliable...LOL.... An 83 cc combustion chamber should get you to a reasonable static compression. 10.0-10.1:1with everything else your doing. You really don't want that ccp to high down there in the south. 190-192 would be sufficient to drive that cam... And yeah compression releases are a darn good idea... Save your starter.... I've always ran a 1.4 kw starter to aid in cranking speed...
Good luck!
Good luck!
There are things that I have taken care of on the bike like wiring issues, changing out lighting, pipes, struts, rebuilding the carb, changing out the air cleaner, fluid changes etc..
For me it comes down to having the time to do it versus having the time to ride. Having worked 60 to 70 hours a week on rotating shifts, not turning down overtime when it was available, time with the family, taking care of things around the house didn't leave a lot of time and In a way it's a good thing I didn't considering the crank work that was needed.
The shop that did the original build had a good reputation as an engine builder, but it didn't go well in my case. Lesson learned.
It's also guys like me that keep shops run by guys like Scott Palmer, John Zanetti and Sean Culleton in business.
I know what you mean Tony, I've been doing 60 hrs a week since last July.. 2 nights a week o/t and Saturdays... sure the money is good but it wears on ya. Thank god my wife is forgiving. Others need to be as considerate... It's not all peaches n cream..... Isn't that what you all southern boys in Georgia like?.... Lol.....
It's been my experience that 170-180 psi cranking pressure is where the HD starting system starts to throw in the towel.
If you hit the starter on a hot motor and there's any hesitation or obvious stress on the compression stroke (assuming all electrical components are up to snuff), you need CR's.
The 35 years we've been together she was really understanding with all the shift work...nights, weekends, holidays. The towing and petroleum businesses are 24/7/365. The OT is nice, but I'm finally off the shift work and we're enjoying being able to spend more time together.
My next door neighbor in Sunrise was from Queens and is good friends with Andrew Rosa. Back around 1987 I remember him tearing his bike down to the frame to repaint and sending his motor to Andrew to rework. He still gets together for a ride with Andrew when he goes back to NY to visit.
