Getting up close and personal
Old 12-30-2018, 01:28 PM
Newharleylover's Avatar
Newharleylover
Newharleylover is offline
Received 1,165 Likes on 456 Posts
Although according to what my most recent research is it should be up around 150
Old 12-30-2018, 01:35 PM
WP50's Avatar
WP50
WP50 is offline
Received 1,875 Likes on 1,270 Posts
Originally Posted by Newharleylover
Compression on the rear cyl is 112, front is 110. The wet test made no discernable difference. I did this after I ran the engine for 15 minutes. Assuming I did this correctly I can make the deduction that it's ok.
Did you have the throttle at wide open while doing the compression test??
It can make a good size difference in the reading you get.
110 is on the low side.
WP
Old 12-30-2018, 01:49 PM
Newharleylover
I held the throttle wide open and that's what I got. I have a couple of things to do in the next little bit but I'm prepared to do it again just for piece of mind. According to what I found out yes it's low. Funny thing is that since I got the bike at the end of May I've put 4500 miles on it and I've added a little short of half a quart. Unless I'm way out to lunch I thought that was pretty good. It doesn't smoke at all.
Old 12-30-2018, 02:55 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
Your service manual will tell you that you need 90 psi minimum.
Normally you should see around 160.
As long as the 2 cylinders are within 10% of each other you are good.
Why are you worried about the compression is the bike running bad?
Old 12-30-2018, 03:21 PM
Newharleylover
The guy I bought it from mentioned that it had been rebuilt at one time according to the guy he bought it from so I did the compression test for my own reference. While it's down for the season I thought I'd dig into it and find out for myself. OK last summer I was on my way home from work and all of a sudden it lost a major amount of power so I pulled over to check it out. I had a small amount of tools in one of the bags and found that it was getting fuel so I checked the plug wires and found that the front cylinder plug wire popped off of the coil. It was a bitch to reach but I got it reconnected and it fired up. I'm not sure if it's my imagination or not but since then at idle it sounds to me like each cylinder isn't firing evenly. It's hard to describe but if you pulled off one plug wire while it's running is what it sounds like. I bought new plug wires and put in new plugs but because the wire fits so loose in the coil I imagine that I need a new coil. Just assuming that that's maybe why it sounds odd at idle. The compression test was only to eliminate that part of it I guess.
Old 12-30-2018, 03:53 PM
Newharleylover
As as side note before I bought this bike I had a 2009 RKC I bought new. Since I've bought this bike my opinion is that it's a much better bike for several reasons. So even though it has a few problems I'd rather invest the time and $ in this bike than to walk away
Old 12-30-2018, 05:12 PM
texashillcountry
Dirt don't hurt
What exactly are the problems?
If your bike has plenty of power for you and runs good then ignore what you got for the compression tester.
Don't forget that your problem might be in the tester rather than in your compression.
Old 12-30-2018, 05:54 PM
Newharleylover
The few problems would have been better worded as things that may need attention. There's no risk of complete failure by any means. Your input on compression is appreciated, I'll leave it alone. I have a few old wiring repairs to correct then I'll finish the tear down for paint.
Old 12-30-2018, 06:01 PM
texashillcountry
Dirt don't hurt
It's always best not to fix something that isn't broken.
Old 12-30-2018, 06:07 PM
WP50's Avatar
WP50
WP50 is offline
Where's the fun in that???
WP
Quick Reply: Getting up close and personal
