Starting to understand my old bike.
Newly acquired 1985 FXWG with Evo engine and 4 speed, belt drive rear wheel.
Please correct me if I'm wrong. This is how I believe this works.
The primary (wet) breaths through the hollow tranny shaft where the clutch push rod goes through. Then both primary and tranny vent through a small hole in the top at the back of the tranny. Is this how it works? Thanks.
As stock?? The oil in the primary is Recycled by the oiling system... needs to put a vacuum on the Primary..
the tranny does indeed breathe thru the hollow stud on the cover...
If Modfied such that you want the Primary to breath... you can pull the small seal around the clutch pushrod... or Use the "feed" line [if not utilized due to modification]
HTH
BTW to better understand the drivetrain of that particular model [minus engine] you need to go to the Shovelhead forums...
HTH
Be very careful of Generalizations... again... the Shovelhead forums have the proper information concerning the 4-speed Evo...
BTW... there is one in the Shop right now... so if ya need to "see" something.... LMK
and again... more knowledge of the 4-speed in the Shovel section... while the EVO engine, and later components belong here... but... you'll figger it out..
I will check, but, I assume they vented thru the Mainshaft. as they were Not equipped to oil the Chain externally..
