Tappet Blocks Billet or Cast??
Old 11-17-2018, 04:40 PM
jcsurf's Avatar
jcsurf
jcsurf is offline
Default Tappet Blocks Billet or Cast??
Getting ready to replace my tappet blocks, is there any advantage to using billet over cast ones? Besides, billet cost twice as much as cast.
Old 11-17-2018, 05:33 PM
daven9113's Avatar
daven9113
daven9113 is offline
As long as the bores are smooth and fitment is good; other than looks, I don't think you would notice the difference, except in your wallet. Show bike or ride bike?
Old 11-17-2018, 05:43 PM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,413 Likes on 1,728 Posts
My Original cast blocks are at 80k miles... and need bored oversize... think I'll Keep 'em...
Old 11-17-2018, 06:04 PM
jcsurf's Avatar
jcsurf
jcsurf is offline
The bike is an everyday rider, 40,000 miles. Doing a little winter fixing up.
Old 11-17-2018, 10:14 PM
daven9113's Avatar
daven9113
Is there a reason you are replacing the tappet blocks? Not a common service replacement item for winter fix ups.
Old 11-17-2018, 10:40 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 49,005 Likes on 17,908 Posts
Cast will wear better and longer than the pretty ones and there's a lot of side load torque on lifters
Old 11-18-2018, 04:47 AM
jcsurf's Avatar
jcsurf
jcsurf is offline
The outer front bolt hole corner cracked off, time to replace it.
Old 11-18-2018, 04:48 AM
jcsurf's Avatar
jcsurf
jcsurf is offline
On the front one.
Old 11-18-2018, 08:24 AM
Racepres's Avatar
Racepres
Racepres is offline
Hiuh??? Some serious stress to accomplish that ... in fact... Never seen it from "Use" before.
I would find out How/Why before I replace anything!!!
Old 11-18-2018, 09:11 AM
Kingglide549's Avatar
Kingglide549
Kingglide549 is offline
I use S&S being mine was on the loose side.
In the processes of tightening up oil clearances to the valve train, it was a step.
The clearance for the bores in lifter to lifter block is supposed to very small- that is way they get honed to OS, or replaced.
With new lifters, it is "pretty much a "pug " fit.
IDK if S&S are cast, boiled, or what proses they use to make them.
They are bulkier, as I had to grind quite a bit off one to get it to drop in past the cylinder on the rear (I think it was the rear)
Quick Reply: Tappet Blocks Billet or Cast??
