Floating brake rotors or not?
Old 11-15-2018 | 03:02 PM
FreedomRider's Avatar
FreedomRider
Looks Good … take care of them and they'll last for another generation
sB43 (11-15-2018)
Old 11-15-2018 | 04:20 PM
bentparts's Avatar
bentparts
Talking rotors
Floating rotors are less apt to warp... They cool better then solids....
That's one of the benefits, most are drilled and /or slotted too with aluminum carriers making them lighter. Less unsprung weight is always a good thing. I use EBC floaters with their most aggressive pads and PM 6 piston calipers. I found the stock brakes ( 88 FLHS ) more like a suggestion to stop. I sometimes ride pretty hard in the twisties and good stopping power is mandatory, especially if you did a bunch to make it go faster.
Old 11-15-2018 | 05:20 PM
98hotrodfatboy's Avatar
98hotrodfatboy
I've had floater from southern motorcycle works that were aluminum centers with steel rivets and the aluminum wore at the Roberts causing the brake rotor to be very loose and unusable. Doubt I even had 10k on them. I would not recommend floaters with aluminum centers..
Old 11-15-2018 | 06:36 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I've had the stock rotor on the left side of the front wheel for 150k now...no issues.
Old 11-15-2018 | 07:12 PM
98hotrodfatboy
That's pretty impressive. You must have shimmed the caliper properly... Or your one of those guys that doesn't use his front brakes... Lol..
Old 11-16-2018 | 06:39 AM
texashillcountry
Dirt don't hurt
I've got the calipers on the bike but I'm still trying to figure out how they work.
I suspect it has something to do with that stick looking thingy that hangs out in front of the throttle but I keep forgetting to try it and see if that's what it does...
Old 11-16-2018 | 08:02 AM
grbrown's Avatar
grbrown
Full floaters, for sure. If you live on the plains and rarely tackle mountains, your brakes may never get to do a lot of work. Living in the UK and with access to the Alps then the rules change! Going downhill for what seems like countless miles, negotiating endless tight hairpins the brakes, hands and wrists all get a major workout, sometimes requiring a rest partway down. In those circumstances, aftermarket rotors, pads and braided hoses are a must IMHO. I currently have EBC rotors and pads front and rear, although they haven't done much work yet.
sB43 (11-16-2018)
Old 11-16-2018 | 03:20 PM
bentparts's Avatar
bentparts
Default Rotors
Definitely not shitty Chinese made ones, stick with a reputable company.
Old 11-16-2018 | 04:33 PM
98hotrodfatboy
I did, they machine their own rotors to match the cnc rims...
Old 11-16-2018 | 04:40 PM
smitty901's Avatar
smitty901
My 19996 has factory rotors front and rear. If they ever start to give me problems I would remove them save them and put floating on.
Quick Reply: Floating brake rotors or not?
