Need Help? Kick start and Evolution
Old 09-29-2018 | 10:56 PM
glidein wide's Avatar
glidein wide
I run the dynatec S ignition system in my evo,centrifugal advance and disconnected the voes,that's all you need.
Old 09-30-2018 | 12:41 AM
ROCKOUT Rocker Products
Sponsor
I did the aftermarket (Custom Chrome I think) kicker on my '91 Softail. Installation was straightforward... worked ok. Can't speak to longevity as i sold the bike shortly after completion. As noted in another post your choice of pipes will be limited to clear the kick arm, or you can do what I did & get an extended offset arm. One warning.... the whole thing eats up some legroom.... it will make you bowlegged on one side
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old 09-30-2018 | 07:08 PM
splattttttt's Avatar
splattttttt
Only kicker I ever owned was an RZ350
eventuLly carb issues made starts a PITA
Still fantasize about kick starting a bike. These look best on rigids IMO
Old 09-30-2018 | 07:35 PM
TwiZted Biker's Avatar
TwiZted Biker
Or you do what most us old shovel guys do and fold it out when riding. Solid arm on mine but the brass pedal vibrates out within a couple miles without fail otherwise it's in the back of the knee.
Old 09-30-2018 | 09:21 PM
monckywrench's Avatar
monckywrench
If the kicker is to look cool and play "biker" buy a cheap kit and don't use it more than enough for manly starts in front of hot babes (or do a "Bronson" start and hit the electric start button when your begin your kick). Evo electric starting systems (especially the later Denso units vs. the early Hitachi) are excellent so there's no functional need for a kicker.
If it's for daily use, buy a Baker. My Custom Crap kit ratchet stripped and did very unpleasant things to my knee. I replaced the ratchet and gears with a Baker four speed set solving that problem and threw the soft stock arm and pedal in the trash replacing them with Baker and later a stock folding Harley arm for comfort because I run mid controls. The Baker arm went to one of my Shovels. Baker make VERY NICE parts. Even my jaded pro machinist bros enjoy fondling them! That came in under Baker cost but I'll never try to cut that corner on critical parts again. The case sticks out annoyingly if you run mid controls which I do. I didn't transfer the kit to my upgraded trans. It was a waste of time but educational. I also upgraded the throwout bearing, and did migrate that to my later transmission. https://bakerdrivetrain.com/products...ut-bearing-kit
After my knee got better I kicked myself in the azz for cheaping out. If it had taken longer to heal I'd have paid a friend to kick me in the azz for cheaping out. Don't cheap out on parts which can hurt you. I grew up kicking and continue to kick Britbikes, HDs and older Japanese machines. It wasn't operator error.
texashillcountry
EVO
15
10-02-2018 04:37 PM
Nate.Evans
05-11-2018 09:39 AM
blackpanhead53
EVO
12-13-2013 04:58 PM
spiritlover
EVO
01-24-2013 12:41 PM
Chopper-d
EVO
13
10-17-2012 11:09 PM
