FXR charging System
Old 07-24-2018, 08:20 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,867 Likes on 2,429 Posts
Originally Posted by Eowright
could bad rotor do this? I never replaced it
The rotor is a solid state magnet and hardly likely to cause any problems. So no, it cannot do any harm, unless it somehow breaks up (I have heard of Sporty ones doing that, but not big twins).
Old 07-24-2018, 08:47 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 20,189 Likes on 5,847 Posts
The theory is that primary oil in the regulator- stator connection is causing an arc and fries the plugs.Any opinions?? Thanks!!
Oil is a very good insulator and is not the problem...all large transformers are filled with oil.
Old 07-24-2018, 09:17 AM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
Word, I hear you guys and thank you for your help! I probably will go that route but don’t want to throw new parts again at a recurring problem. I guess my question is: Could the plugs fry like this from a wiring issue or is a bad connection the only way this could happen?
When you replaced it 4 years ago did you use OEM or aftermarket parts?
Old 07-24-2018, 10:07 AM
0maha's Avatar
0maha
0maha is offline
Received 4,678 Likes on 1,665 Posts
My FXR (1990 model) had a little spring clip thingy like this to keep the plug engaged. Don't know if it was factory or not, but my Electra Glide (also a 1990) doesn't have one.
I concur with the others: A bit of oil isn't going to cause the connection to fry.
Also, the original posting (with the screen shot from redit) is incorrect in saying that you need to pull the inner primary to get to the stator.
A few years ago, the voltage regulator on my Electra Glide went out. At the time, I didn't know any better and replaced it with an Accel regulator. Maybe a year later the stator went out. I replaced that with an Accel stator. Everything is holding up just fine so far, but if I had it to do over again, I'd replace them as a set and go with a higher-powered Cycle Electric setup.
The best thing I ever did for the electrics on the Electra Glide was replace all the lights with LEDs.
For the stock-style plug (and the design does indeed suck) its critical that you get the stator side fully seated in the hole in the inner primary so as to allow for a clean connection with the plug from the regulator.
I think Sir Graham is on to something. The fried plug may be the symptom, not the cause.
Old 07-24-2018, 10:29 AM
Eowright's Avatar
Eowright
Eowright is offline
6th Gear
thanks. I agree, the connection is not the problem. Something else is causing it to cook. I could get new parts and hard wire but then wires could just fry if I’m putting band aid on a stab wound
Old 07-24-2018, 11:56 AM
Daedalus's Avatar
Daedalus
Daedalus is offline
Are you making the most miles on the highway in higher rev ranges?
Old 07-24-2018, 11:59 AM
Eowright's Avatar
Eowright
Eowright is offline
6th Gear
yes definitely
and texashillcountry
i replaced regulator and stator with drag specialties brand
Old 07-24-2018, 12:35 PM
Daedalus's Avatar
Daedalus
Daedalus is offline
yes definitely
Thought so
The thing is, these dynamo's always get stressed to the max. On one end you have a stator, a copper wig that is meant to induce a current, on the other hand you have a permanent magnet. In other words, there is nothing to regulate in the dynamo to control the height of the voltage. The voltage is kept at bay by consuming amps.
As simply put as possible, when the electrical components consume 1/3 of the generated watts, the regulator needs to burn 2/3 to keep the voltage at lets say 13.8 volts, and thats what it does. So basically, your dynamo is always pushed to the max in general, and specifically at high revs, where max mechanical power is partly transformed into electrical power. Since your are mostly on highways in higher rev ranges, your dynamo is generating to the max, and your regulator is burning to earth to the max, and everything goes through that one connector.
Long story short, try to measure how many amps go through that wire, and try to compare this with others. If - for whatever reason - the magnetic force of your rotor is stronger then others, your dynamo coughs up more amps than normal, specially on the high revs your engine is doing. If so, you could try a weaker rotor, if there is any. If the measurements are comparable, then the connection - at a certain point in time - must become the culprit. Alternatively, if you are planning to install a 6 gear builder kit, that might have positive side effects for this issue as well (read, lower revs == lower amps output)
Hope this makes sense. My technical English is still a bit rusty...
Old 07-24-2018, 01:56 PM
Eowright's Avatar
Eowright
Eowright is offline
6th Gear
Thought so
makes sense. Thanks man!
Old 07-24-2018, 03:39 PM
texashillcountry
Dirt don't hurt
And that IMO is why it's toast now.
Chinese crap will never work as well as quality made parts.
For your charging system use only OEM or Cycle Electric if you want it to last.
Quick Reply: FXR charging System
