Will a twin cam dyna exhaust fit on a evo dyna. I'm not just talking about the pipes themselves fitting in the exhaust ports but the mounting brackets and such. Thanks Guys.
i've swapped pipes from twin cams to evo's before...only time I had a problem was I got an exhaust for a foot peg bike an couldn't get it to clear a foot board bike.
I have an aftermarket twincam system on my 1990 Glide. Will everything bolt right on as if it was made for your bike? Probably not! Will it be straight-forward to adapt it? Certainly. If you have your Evo brackets plus the TC ones you should be able to make things work.
