Evo Tool Kit
Evo Tool Kit
Hey boys,
So after having a minor roadside event this weekend, and having to "phone a friend" to get tools, I realized that I need to stop dragging my feet on buying that toolbag for my bike.
Has anyone here created the Master List of needed tools to stock a bag for an Evo? This sounds like a Prot or Graham kind of post, but others might have this also.
-Tool-less in Oklahoma
I just used tools in South Central OK yesterday. Highways 69 and 75. How about that?
Get a fork bag. Fill it with pawn shop tools or go nuts at Harbor Freight, then put it in the saddle bag. Combination wrenches from 1/4" to at least 9/16". Set of allen wrenches and if you have room, 3/8" drive allen sockets. 3/8" drive socket and a wobble extension or two. "Mexican Speed Wrench," AKA adjustable wrench, AKA "Crescent wrench" of at least 10 inches and big enough for the back axle nut (1-1/16".) Standard size vice grips. Side cutters. Needle nose pliers. 3/8" drive sockets, preferably 6 point, but whatever you can find cheap. Screw driver that takes bits. Set of screwdriver bits. 10mm combination wrench. Zip ties. Length of wire. 1/4" 12 point socket. Spark plug socket. A standard #2 Phillips screwdriver. A smaller flat blade screw driver long enough to adjust the carb. Mini vice grips.
The crescent wrench and standard size vice grips may or may not fit in the tool bag, but I consider them essential. With that, you can take apart and put back together 90% of your bike.
Ask Me How I Know...
The following 2 users liked this post by Dr.Hess:
JakeC7R (06-30-2018),
Matt990724 (06-25-2018)
Received 4,361 Likes
Add the Speed Wrench and a 1/4" 12 point socket and/or combination wrench (critical) for tightening down lifter blocks and that would about do it. I still think a small 3/8" socket set is needed too. Even just the ratchet and a strip of sockets. They don't take up much space. Oh, if you're planning on pulling a head, you'll need a 12 point socket for that.
Yes, I know that stretch of road well! I trust you got on down the road ok?
Received 5,440 Likes
