Evo Tool Kit
I know my Dyna and my bagger have them. I thought my FXR had some torx bolts too. Guess I’m wrong. Too lazy to go downstairs and look.
You will need a torx socket to pull your fuel tank. For fuel injected bikes that need a head temp sensor replaced, a torx socket and deep well socket are required to make the repair (assuming you carry a spare head temp sensor). My Road King eats those stupid sensors like candy.
For a basic tool roll, I bought one of these: Well thought out and they packed stuff in there you might not have thought about.
carl
carl
The killer problem with the EVO if you have other then a stock cam
is the NON-tapered pinion shaft.
That little nut that holds the drive for the cam can come lose.
There is not much of a key to hold it all in place.
If I was going on a big trip I would check that now rather on the road.
Bent valves are a bummer to fix in a parking lot.
BTDT
Mine is now welded. ( tigged 2 spots)
Yes I can grind the spots off and remove it when the time comes.
I am not wanting to buy that T shirt again !
BTDT
Lowes Kobalt 1/4" drive socket set with ratchet and extension
Small wrench set
Needlenose pliers
Crescent wrench
Vise grips
1/4" Vacuum Plugs x2
Allen wrench set
Baling wire
Zip ties
Electrical tape
BIC lighter wrapped in duct tape
spare rocker gaskets
spare circuit breakers
spare starter relay
multi bit screwdriver
Small wrench set
Needlenose pliers
Crescent wrench
Vise grips
Allen wrench set
Baling wire
Zip ties
Electrical tape
spare starter relay
Matt990724 (06-26-2018)
Roger Williams
08-16-2013 02:41 AM
