How’s this plug look
Old 06-09-2018, 10:01 AM
Kingglide549's Avatar
Kingglide549
Kingglide549 is offline
Originally Posted by Numa Albornoz
Don’t worry I’m very open minded and don’t mind learning something new, that’s why I came on here.
Ok something not so new but new in the Harley thing is, and I am not sure why
Install an AFR gauge RIGHT NOW! and you will be the happiest you have ever been.'
Once there they are the ultimate addition and addiction.
Get a wide band-Amazon sells them.
This takes ALL the guesswork out it.
In fact, most people have no clue how to do a REAL plug check
(you have to kill the engine pull in the clutch coast to a stop and THEN you get a reading for what you were just doing.)
This is the caveman way and very time consuming and less than accurate, not to mention all the time used on the side of the roads is sort of dangerous.
Old 06-09-2018, 10:37 AM
Ironworker69's Avatar
Ironworker69
Ironworker69 is offline
Received 2,127 Likes on 1,337 Posts
I’ve looked at those AFR things. Do you need to drill into your garage exhaust
Old 06-09-2018, 02:22 PM
Ironworker69
Here’s a side shot after a few more miles
Old 06-09-2018, 03:44 PM
Kingglide549
Yup, about a 1/2 inch hole saw will do it on the back side of the front pipe (out of sight) and weld the bung in that comes with the kit.
The AFR is one of the best mods you will ever do to your bike.
Old 06-09-2018, 04:28 PM
Ironworker69
interesting, how different are the readings in relation to the weather.
Old 06-09-2018, 06:20 PM
Kingglide549
Extremes?
IDK But from say 40s F to 100sF not much.
At least none that I have noted.
Old 06-09-2018, 08:48 PM
Yankee Dog's Avatar
Yankee Dog
Yankee Dog is online now
Received 2,043 Likes on 1,031 Posts
ubreal (09-29-2018)
Old 06-09-2018, 09:04 PM
Kingglide549
The above pic ^^If you can get real gas, and if you want to do numerous to plenty of stops and pull the plugs..
The AFR unit is the wave, .catch it
Old 06-10-2018, 07:44 AM
1997bagger's Avatar
1997bagger
1997bagger is offline
Received 1,787 Likes on 891 Posts
This plug is from a tuning with a Digital Wego AFR reader
Old 06-10-2018, 11:00 AM
Mattbastard's Avatar
Mattbastard
Mattbastard is offline
Received 1,414 Likes on 865 Posts
So is that actual hardwood or that fake plastic stuff? Either way, I like the look.
My 1933 Cape Cod house in Sheboygan had maple hardwood on the 1st floor, I loved the look.
Quick Reply: How’s this plug look
