92 FXR no spark
92 FXR no spark
Two weeks ago had problems with spark. New plugs and new plug wires. Checked power to coil and found no power. Added new wire from coil to ignition switch. Started and ran fine.
Lost power on ride. Checked coil, have 12+ volts. Plugs seem dirty for how new they are. (Just replaced jets and cleaned carb)
I don’t know how to test the coil, do I take in it to be tested or do I just start with a new ignition coil or do I start with a new ignition module? (Dyna twin fire II coil, unsure of module, not factory)
Received 4,361 Likes
That said I had a coil that passed all the tests but still wouldn't spark.
I replaced it with an aftermarket coil and it's doing fine to this day.
