Oil leak pissed
Received 23,954 Likes
Mattbastard (05-24-2018)
Here is exactly what I used and it worked very well. It's made for Marine applications. My exhaust burned through the casing.... No more leaks...
https://www.ebay.com/itm/1-FOOT-3-4-...oAAOSwB-1Yzly8
You will need to disconnect the cable from the trans to slip it on..... Clean the cable housing with alcohol....
You might get away just loosening the adjusters and removing the lever end to slide the heat shrink tubing down the cable, then hitting it with a heat gun.
That is, of course the leak is actually coming THRU the cable as opposed to around the o-ring that may or may not be on the business end of the cable.
