New clutch cable won't screw into transmission cover
Trying to replace my clutch cable. Got the old one out all the way, can't get the new one to lock into the threads on the transmission cover.
I also can't get the old one to screw back in again either, so I'm wondering if there's a trick to it that I'm not getting right?
Transmission cover is all the way off the bike. Thanks.
Location: Depends on who wants to know.........and why.
Received 1,902 Likes
rainsong (05-23-2018)
Grabbed a tap & die set at O'Reilly's 5 minutes before they were closing, turned the tap through the cover and then it went in first try.
Thanks for the advice!
Received 5,734 Likes
Becareful using a tap as you may open the threads enough to weep trans oil.
Maybe use a "bottoming" tap and go the first 3-4 threads...
OP~ while you're there, you might as well install a Burley EZ boy clutch device. Reduces lever effort 40% but has the same lockup as before.
People are impressed how well they work, myself included. (I've put them on a few Evo's and Twinkies, over the years)
