Slow cranking starter.
https://www.hdforums.com/forum/evo-c...king-87-a.html
My 88 FLHTC has been cranking real slow. Much like what the OP describes in the link above. I followed Dr.Hess suggestion in the link and tested the voltage. I found that the voltage drops significantly at the terminal on the solenoid where the power wire goes to the starter when I push the start button.. The voltage at the other terminal is equal to the voltage at the battery when I hit the start button. Does this mean that the solenoid is bad and needs replaced or is there another problem? I did check for loose connections and found none.
Voltage across battery terminals before trying to start: _________
Voltage across battery terminals while trying to start: _________
Voltage at the solenoid post connected to the battery while cranking: _________
Voltage at the solenoid post connected to the starter while cranking: _________
If the voltage is different between the two solenoid posts while cranking, it sounds like you're getting a voltage drop there, which could very well be bad contacts inside the solenoid.
My 86 always had starter stall,especially when cold, hit the button a second time usually gets it cranking.and always used Mobil 1 15-50 showing no wear after 34k
Paul Lessard (03-02-2023)
These two posts should be connected together inside the solenoid when the plunger pulls in, so the voltage at each of them should be the same, or very nearly so.
Looks like a probable bad solenoid to me.
